void queryTask_ExecuteCompleted(object sender, QueryEventArgs e)
foreach (Graphic item in e.FeatureSet.Features)
Graphic queryGraphic = new Graphic();
ESRI.ArcGIS.Client.Geometry.MapPoint mapPnt = new MapPoint(item.Geometry.Extent.XMax, item.Geometry.Extent.YMax);
queryGraphic.Geometry = ESRI.ArcGIS.Client.Bing.Transform.GeographicToWebMercator(mapPnt);
queryGraphic.Geometry.SpatialReference = sReference;
BufferParameters bufferParams = new BufferParameters()
BufferSpatialReference = new SpatialReference(102100),
OutSpatialReference = MapaGM.SpatialReference,
Unit = LinearUnit.Meter,
bufferParams.Distances.Add(1000);
bufferParams.Features.Add(queryGraphic);
geometryService.BufferAsync(bufferParams);
void geometryService_BufferCompleted(object sender, GraphicsEventArgs e)
Graphic bufferGraphic = new Graphic();
bufferGraphic.Geometry = e.Results[0].Geometry;
bufferGraphic.Symbol = LayoutRoot.Resources["BufferSymbol"] as Symbol;
bufferGraphic.SetZIndex(1);
pointAndBufferGraphicsLayer.Graphics.Add(bufferGraphic);
Solved! Go to Solution.
You should be able to pass all the features returned from the QueryTask to the Buffer. The code below works for me
void QueryTask_ExecuteCompleted(object sender, QueryEventArgs e) { FeatureSet fs = e.FeatureSet; if (fs.Count() == 0) { MessageBox.Show("Sorry, no data matches your query. Please try again", "Query Error", MessageBoxButton.OK); } else { BufferParameters buffParam = new BufferParameters() { Unit = LinearUnit.Meter, BufferSpatialReference = _Map.SpatialReference, OutSpatialReference = _Map.SpatialReference }; buffParam.Distances.Add(500); buffParam.Features.AddRange(fs.Features); GeometryService geoService = new GeometryService("http://<servername>/ArcGIS/rest/services/Geometry/GeometryServer"); geoService.BufferCompleted += (send,args) => { GraphicsLayer gl = (GraphicsLayer)_Map.Layers[_GraphicsLayer]; gl.ClearGraphics(); gl.Renderer = LayoutRoot.Resources["SelectRendererPoly"] as IRenderer; //polygon renderer defined in XAML foreach (var g in args.Results) { gl.Graphics.Add(g); } gl.Refresh(); }; geoService.BufferAsync(buffParam); } }
