(Solved) - Installed a new patch ArcGIS-1041-PFA-SEC2017U1-Patch-linux.tar
Hi guys
I installed Portal for ArcGIS Home Application Upload Patch for linux today, my Portal stopped to work after that.
It was created a extra folder called linux.portal at Portal installation Folder.
I run portaldiag to check the requirements and now I got a Warning Diag_26
DIAG000: Check for installation as root [PASSED]
DIAG001: Check for 64-bit architecture [PASSED]
DIAG002: Check OS version [PASSED]
DIAG003: Check hostname for invalid characters [PASSED]
DIAG005: Check system limits [PASSED]
DIAG004: Check installed packages [PASSED]
DIAG006: Check OS patches [PASSED]
DIAG016: Check Portal for ArcGIS ports [PASSED]
DIAG024: Check localhost resolution [PASSED]
DIAG020: Check hostname IP address mismatches [PASSED]
DIAG026: Check processes of Portal for ArcGIS core services [WARNING]
DIAG028: Check data directory [PASSED]
DIAG029: Check file system type [PASSED]
There were 0 failure(s) and 1 warning(s) found:
WARNINGS:
*** DIAG026: One or more core services was not started. Start Portal
for ArcGIS by running the startportal.sh script or restart Portal for
ArcGIS if it is already started.
Any idea to help me? Reinstall Portal will be terrible for me
Thank you.
