Hi, I am trying to configure ArcGIS License Manager on our Azure Server so that our users can run ArcGIS Pro. I have done everything advised in the article https://support.esri.com/en/technical-article/000024588 but need to know what the detailed requirements are for setting "Ensure the ArcGIS License Manager and vendor daemon ports are open in the Azure virtual network and Azure Application Gateway".
Our ArcGIS Enterprise is set up in a standard way on Microsoft Azure using Esri's recommended JumpBox & Enterprise Server configuration. What I need to know are where do I make the Firewall, Port, etc settings? Are these in Defender on the ArcGIS Enterprise Server, Defender on the JumpBox, Azure Inbound Port Rules on the JumpBox virtual machine or the Azure ArcGIS Enterprise VM. Are there additional settings on the Azure Application Gateway?
It'd be great if there was a detailed guide on where & what all of these settings are as there are too many combinations or places to set.
