Oracle 10.2.0.5.0 on HPUX 11i
1443
06-07-2016 05:46 AM
MarceloEdy_Peinado
I have a compatibility trouble!
I have a Oracle 10.2.0.5.0 server hosted on HPUX 11i and I would like use the functions from Esri ST_GEOMETRY in ArcGIS 10.3.1.
Is it possible?
Thanks and regards!
Marcelo E Peinado
GIS Consultant
Optimus GIS & IT
George_Thompson
Esri Frequent Contributor
Hi Marcelo,
Here are the system requirements for 10.3.1 and Oracle:
DatabaseSupported Operating System(s)Minimum OS VersionMaximum OS Version
Oracle 10g R2 (64 bit) 10.2.0.3
Click here for Database Requirements
IBM AIX 6.1.0.0
Red Hat Enterprise Linux AS/ES 5 (64 bit)
Update 7
Sun Solaris 9 (64 bit [SPARC])
Sun Solaris 10 (64 bit [SPARC])
Windows 2008 R2 Server Standard, Enterprise & Datacenter (64-bit [AMD64/EM64T])
SP1
Oracle database requirements for ArcGIS 10.3.x—Help | ArcGIS for Desktop
I do not see HPUX 11i as a supported environment for the Oracle geodatabase. I also believe that the ST_Libraries are coded for a specific OS that Oracle is installed on.
Hope this help.
Geodatabase
--- George T.
MarceloEdy_Peinado
Hi George,
I'll do a test using the lib_st library from ArcGIS 10.1.
Thanks a lot!
Marcelo E Peinado
GIS Consulting
Optimus GIS & IT
George_Thompson
I would not recommend mixing the version of the geodatabase and the ST library. Keep them at the same version/patch level.
--- George T.
