I'm looking to build a custom widget where the user will select a feature layer (in this case points collected on site).
From this I want to make a table which will show the OID of the point, other field values but most importantly, a sum of the attachments at that point.
How can this be done through the custom widgets? Currently able to access this information through arcpy using
for feature in features:
oid = feature.attributes['OBJECTID']
attachments_info = layer.attachments.get_list(oid=oid)
if attachments_info:
for attachment_info in attachments_info:
att_id = attachment_info['id']
filename = attachment_info['name']
attachment_list.append({'OID': oid, 'AttachmentID': att_id, 'Filename': filename})
attachment_df = pd.DataFrame(attachment_list)
This is returning a dataframe with the OIDs and their attachments. I would like to achieve something similar in a custom widget.
Thanks!
