ArcGIS for AutoCAD Blog
77
5K
6
POST | Hello,I have run into an issue where data imported using ArcGIS for AutoCAD is not being reprojected properly if the ... by DerekBannon22 New Contributor II 0 1 | 0 | 1 | 35 | |
POST | I am using Autocad 2022 with Arcgis for Autocad 420. I am using esri_weblayer_add to add several several layers from... by jmeyer7 New Member 0 0 | 0 | 0 | 63 | |
POST | I have AutoCAD 2025 and I am trying to load Arcgis for AutoCAD and it is not loading. I am not getting any errors or ... by RuszkowskiRen New Contributor 0 3 | 0 | 3 | 190 | |
POST | Hey everyone, I am using ArcGIS for AutoCAD 430 and my main goal is to bring in my water utility's map in order to ev... by mmurphycpw New Contributor 0 3 | 0 | 3 | 201 | |
POST | Hello, I am having an interesting problem with the ArcGIS plugin in Civil 3D. I have been using it for a while and di... by hancer New Contributor 0 1 | 0 | 1 | 118 | |
POST | I am trying to print a PDF with the GIS data added. They all show in the layout space, but on the PDF created, only s... by whitecosmos New Contributor II 0 7 | 0 | 7 | 226 | |
POST | When I save, close and reopen my .dwg file, all the GIS layers previously added from our organisation's portal are go... by whitecosmos New Contributor II 1 2 | 1 | 2 | 148 | |
POST | Hi,I‘m AutoCad 2024 and just started testing this ArcGIS plugin. I have defined a project area, and I can see its out... by whitecosmos New Contributor II 0 3 | 0 | 3 | 200 | |
POST | After updating from Version 420 to Version 430 of the ArcGIS plug-in for AutoCAD, I'm no longer able to see ESRI map ... by StephanieDonoghue New Contributor 1 2 | 1 | 2 | 291 | |
POST | 0 | 1 | 180 | ||
POST | Hello all, I'm trying to help one of our engineers install the ArcGIS for AutoCAD plug-in so they can import our publ... by Caitlin_Todd_LCOR New Contributor III 0 2 | 0 | 2 | 242 | |
POST | I installed the new ArcGIS for AutoCAD 430 plug-in and successfully connected it to my enterprise and ArcGIS Online.I... by Jack_in_the_box New Contributor II 0 2 | 0 | 2 | 316 | |
POST | After logging into our portal on ArcGIS for AutoCAD, I have a user that is unable to see any of the portal layers wit... by DerekBannon22 New Contributor II 0 7 | 0 | 7 | 340 | |
POST | I have a CAD file with a polyline layer. Some of the features contain Object Data.When I create a new feature layer o... by yigalm New Contributor III 0 3 | 0 | 3 | 496 | |
POST | I am using the AGIS for AutoCAD for the first time. I published a feature service from Pro. Then I added this feature... by Y_Chau Occasional Contributor 0 4 | 0 | 4 | 396 |
User | Count |
4 | |
1 | |
1 | |
1 |
