I want to create a map using ArcGIS for Power BI that would show more than one layer in the same map visual. Is that possible?
I have water sample results data. I am using the addresses for the point locations. Ideally, I would like to be able to create a map that shows all result values that are not detected (ND) as a specific color and size circle. All results ranging from 0-5 as a different specific color and size circle. All results ranging from 5-10 as a different specific color and size circle, and all results greater than 10 as a specific color and size circle.
If I try to load it all as one table (layer), I don't seem to get the options to be able to specify manual breaks in the values for the results field for size. I can choose the colors I want if I create a new field that creates classes for each of the result value groups I listed earlier, but the size classes, I cannot seem to be able set manually.
If I try to add the data in as separate layers (tables) with filters set for each so to create the color groups that way, it symbolizes all of the layers the same. If I change the color and/or size for one of them, it changes the color and size for all of them as the same.
Is there a way to be able to display data in this fashion to be able to display the data as I need?
Thanks in advance for any assistance.
Lisa D
