Data downloads not working properly
761
01-10-2019 07:34 AM
MattCashen
New Contributor III
I'm having a lot of issues setting up my organizations Hub site.  My current issue is that the downloads for my data are not functioning properly.  All of the shapefile downloads for my data are being downloaded in WGS 84, even though I have local projections enabled.  And the file goedatabase download doesn't download a zipped geodatabase as it should so the resulting download is unrecognizable in ArcMap.  I've created sites where this initially isn't a problem, and then a few hours or a day later this happens.  I have included a link to one of my datasets below so you can look into the issue.
http://data2-lakeingispro.opendata.arcgis.com/datasets/616369f44e4c46cabf14bc9585bb09d7_0
DanielFenton1
Occasional Contributor III
Matt, thank you for the heads up. This issue is now resolved.
MattCashen
New Contributor III
After playing around with some settings, I believe this issue is tied to the New Search Route and API setting.  When I disable that setting, the layers appear to be behaving as they should be.  Since that setting is still in Beta I thought it might be beneficial for you to be aware of this issue.
DanielFenton1
