Heat Map
540
06-10-2022 11:19 AM
Ed_
by MVP Regular Contributor
Hi all,
Is there a way to create a heatmap from polygon data without having to convert polygon to point data?
Thank you,
Question | Analyze | Visualize
AkshayHarshe
Hi @Ed_,
There isn't a way to do so in Insights. May I understand your workflow and why would you need a heat map of polygons?
Akshay Harshe
Ed_
I was wondering if it were possible to convert poly to points on the fly to create a heatmap.
AkshayHarshe
Oh, I see what you mean. It usually needs calculating centroids and Insights doesn't do it at this time. Please submit an idea with your use case(s).
The best approach would be to have the centroids precalculated as a separate layer. If you don't wish to duplicate attributes just have a field that you can join back to your polygons. This way, you can use Joins within insights to create a single dataset that has both polygon and point geometry.
Akshay Harshe
