Selecting a features with Editor widget that overlay each other on the map there is a list of selected items appear on a widget. But this isn't labeled properly in my case. Instead of names I get ids. Does anyone aware what could be the reason of it?
Solved! Go to Solution.
It appears this is driven by the layer's displayField setting. Perhaps you can try setting it to a different field name and seeing if that makes a difference.
Maybe there is some functionality that gives us ability to set what field we want to show in the list of selected features?
Thank you for the reply, it worked.
