I'm having trouble with queries in my app. If you look at this page you'll notice the 'Search by Item' drop-down is blank and the 'Search by Category' displays 'Select one' by default. And when you select a Category with only one Item, such as 'Bicycle Reuse-Donation', the 'Search by Item' drop-down sets itself to that one item. How do I replicate this?
I've been messing around in this section for hours. I can't figure it out? Here's the app on Code Pen.
function addToSelect(values) {
var dOpt = document.createElement("option");
dOpt.value = "";
dOpt.selected = true;
dOpt.text = "Select one";
catTypeSelect.add(dOpt);
values.uCatVals.sort();
values.uCatVals.forEach(function (value) {
var option = document.createElement("option");
option.text = value;
catTypeSelect.add(option);
var dOpt2 = document.createElement("option");
dOpt2.value = "";
dOpt2.disabled = true;
dOpt2.selected = true;
dOpt2.text = "Select one";
keyTypeSelect.add(dOpt2);
values.uKeyVals.sort();
values.uKeyVals.forEach(function (value) {
keyTypeSelect.add(option);
return setDefinitionExpression();
function addToSelect2(values) {
while (keyTypeSelect.options.length > 0) {
keyTypeSelect.remove(0)
dOpt2.value = "";
values.sort();
values.forEach(function (value)
return true;
