I am trying to use OneMap(Singapore Map) multi route function.
The multi route function is completed but it only shows the route and no pointers/markers
Since OneMap is develop using Arcgis map, arcgis manual marker should be able to be implemented into OneMap.
How can i add markers into a map using X/Y Coordinates?
Thank you
