Hi all,
I have 4 ArcGIS Server's registered with Monitor. Each server is set up in a similar way with folders (folders for Aerial Imagery, Locators, Maps, System and Utilities....). If say two servers have a service that share the same name in a folder, is there a way to differentiate them when building an expression? It appears that if the services are named the same and in the same folder on different servers, only one will appear when looking through the services list while building an expression? It probably is just a poor naming structure on our part but didn't seem like it would be an issue until now trying in monitor. Has anyone else experienced this?
Thank you,
Chris
