Attribute Rules in a traditional Versioned Database?
3375
10
07-08-2021 10:14 AM
KimberlyMeinert
Can you set up attribute rules in ArcPro in a traditional versioned SDE SQL Database?  If so, do you have to unversion the feature first and re-version it after setup?  I set the sequence rule up on the feature class connected as the database owner and it seems like it should work, but it doesn't, so I'm trying to trouble shoot.
When I edit the feature as the owner of the database it simply doesn't do anything, and when i switch to my version it says it can't find the sequence, so tries to run but can't.  Any tips appreciated.
KimberlyMeinert
Arcade syntax was all wrong.  (I'm new here.)  I followed the video and it apparently wasn't what I needed.  The other post referenced above had a much simpler version without a variable declaration, one line of code.  Now I know...
ABishop
MVP Regular Contributor
What is the sequence you are trying to use in the attribute rule?  Also what version of ArcPro are you using?
Amanda Bishop, GISP
KimberlyMeinert
ArcPro 2.8.1, I just used the "Create Database Sequence" tool to create a sequence for a couple of features and then used the Arcade expression as detailed in the Esri video below without any extra characters or anything like that.  I just needed a basic unique number.
https://www.youtube.com/watch?v=QPV_ydeoVY0
Discover how easy it is to create a database sequence for new features in your database using a calculation attribute rule and the NextSequenceValue Arcade function. --------------------------------------------------------------------------------------------------- Follow us on Social Media! ...
KimberlyMeinert
Here's a screen shot of my rule.
ABishop
I would try un-versioning the feature class first then set the rule and re-version it.
Amanda Bishop, GISP
KimberlyMeinert
Yeah, I was thinking that too.  I'll report back.  😀
KimberlyMeinert
Nope.  Here's the error.  Same one I got before.
ABishop
I typed in the error to Google search and i found a thread that may help:
https://community.esri.com/t5/arcgis-pro-questions/dbms-sequence-not-found-when-using-attribute-rule...
Amanda Bishop, GISP
KimberlyMeinert
I had read that too and have made...progress?...in that by adding the database owner name before the sequence name, I no longer get the error!  But alas, it also doesn't fill the id either, so I'm trying now to track that down.   I think there's a way to see what number the sequence left off at, I'm curious as to whether that part is actually working and just not passing the value to where it's supposed to go.
KimberlyMeinert
Sequence working on the SQL side...so must be some sort of Arcade syntax issue?
