Georeference CAD Move to Display greyed out
777
12-01-2023 01:02 PM
ElisseDeleissegues1
New Contributor III
What am I doing wrong??
I am using ArcGIS Pro 3.1.3 and attempting to georeference CAD files with a Parcel Fabric version 5. This is a prototype Parcel Fabric and we are currently 'experimenting' and practicing on local drives.
https://pro.arcgis.com/en/pro-app/3.1/help/data/cad/georeferencing-cad-data.htm
The .dwg was delivered with no spatial reference, so the Polylines for importing into the parcel fabric were given a projection via the Define Projection tool. As soon as that was complete, the CAD Data tab appeared as expected. However, the Move to Display command is greyed out.
DA_BIM-GIS
Hello @ElisseDeleissegues1
This is the workflow recommendation now that you are using Pro 3.1
  • On the catalog page select the CAD file
  • Right click and go to properties
  • This will open a window
  • Navigate to the tab Validate Position
  • Assigned the coordinate system.
Because you don't have the "correct X,Y"
  • Use the Suggest Location
    • Enter an address close to the location
  • Open a Map
  • Drag and drop the polyline feature class
    • From the Polyline group
    • Move the Polyline layer outside of the group
    • Select the Polyline layer on the TOC
  • Click Georeference
 Now adjust the file to match the exact location using the georeference tools
Hope this helps
 David
ElisseDeleissegues1
New Contributor III
Perfect! That worked like a charm.
For anyone else that may be having this problem, there is Layer Search as a tab in the Suggest Location window. This has several options to choose from.
  • Assign the coordinate system.
    • Layer Search tab
      • Dropdown options
      • Type value
      • Hit Enter
      • OK
  • Open a Map
ElisseDeleissegues1
New Contributor III
I have one more question before I smash "Accept as Solution"
For the one CAD file that I was successfully able to Georeference, Validate Position page looked like this:
 And subsequent failed attempts (3) at recreating the same workflow resulted in this message:
As well as the Move to Display button again being greyed out.
The Coordinate System and Suggested Location are correct for the failed attempts.
DA_BIM-GIS
Never tested with the search layer workflow.  Let me try it
