How to display 3D point data in ArcGIS Pro?
5312
6
04-09-2015 07:29 AM
GabrielYarlequé
I am working with earthquake data and I want to show the depth of each incident but I can´t display it in ArcGIS Pro. I added my point data, It showed as a 3d layer. However, when I changed the appearance to extrude my point features, they were no longer visible. I tried displaying this data using ArcScene and it worked just fine. Is there any configuration that I need to do before displaying 3D point data in ArcGIS Pro?
Attached is an image of how my data looks in ArcScene.
Robert_LeClair
Esri Notable Contributor
Gabo - go to the Layer Properties -> Elevation and set the "Features are:  Relative to the Ground."  What is your result?
Robert_LeClair
GabrielYarlequé
Hi Robert,
It did work, although the points displayed completely different as they did in ArcScene, and the points disappear when I zoom out, or when I just navigate around. Any thoughts why this is happening?
Thanks
GabrielYarlequé
never mind!..problem solved!
LeeTupuola
Hi Gabriel,
How was this solved?
Cheers,
YorladyVela2
New Contributor III
Hi,, I have a similiar question, I have depht data and I configured the  elevation as relative to the ground but the data are taken like height and not like depth, what else I have to do? Thanks
BruceHarold
Hi Yorlady, attached is the source for a Data Interpoerability Spatial ETL tool that converts USGS-style quake feed GeoJSON to file geodatabase including writing to a custom feature dataset that enables Z values below the default domain limit of -10000.  Note the startup script.  The conversion is from kilometres depth positive down to metres positive up.
