How to share a custom UI in ArcGIS Pro?
2118
19
05-31-2018 10:59 AM
CharlesBailey3
Occasional Contributor II
Is there any way to share the UI customizations in ArcGIS Pro through a template?  I need to use a project package but the pane arrangement, visibility etc. is not carried with the package. I need something similar to the 'Normal.mxt' template in ArcMap which will honor the changes to the default UI and share them along with the package. Is this possible? Thanks, cob
KoryKramer
Esri Community Moderator
I think what you're running into is https://community.esri.com/ideas/11404 but maybe Amir Bar-Maor‌ or Jason Camerano‌ could confirm.
CharlesBailey3
Yeah it's similar, but I'm working with UI panes rather than map views - it
should really just conserve the state of the settings with the project when
it is saved. It does this on the original machine so there's some
incarnation of a 'normal' template saved somewhere, but apparently it can't
be transferred to a recipient machine in Pro. I hesitate to ask, but is
this something that might be addressed through a custom configuration? I
went through the tutorials and saw that the ribbon tabs could be
manipulated, but not sure about the UI panes. Even if so it wouldn't be a
feasible solution for us - we'd have to set up a shortcut to the config on
each user's machine and we are spread out all over the state. But I was
just curious if the dev team considered this to be the Pro way to share UI
settings across computers. Thanks - cob
JasonCamerano
Yea, unfortunately the placement of the actual TASK pane is by default docked on the left side and it can be overlapped by other panes.  We have made undocking the Task Pane and even the Designer pane a best practice for proper usage of Tasks.  I'm not sure of custom configuration of re-skinning the application right now.  As per Kory Kramers link to an idea, that is another feature entirely that has been requested that we have thought about.  Being able to format the views to a certain layout/docking order.
JillHalchin
You can share a lot of the customizations.
These might be helpful.
Quick Access toolbar
More customization
Favorites
CharlesBailey3
This is great, but are you saying these customizations can be shared in a
project, template or package? It seems to me that all of these settings are
saved on the user's local machine and not in the project or template or any
where else I can find... please correct me if I'm wrong... thanks, cob
JillHalchin
It doesn't look like the interface customizations, favorites, etc. go with a package, template or project.  Those are in files in your user profile on your machine (user/appdata/...). The hacks that I linked to tell you which folders/files in your profile will contain the customizations. You can copy those files from your machine and put them on another person's computer, or on another computer that you use. Because the files go in the user profile, each person who uses the computer will need the files added to their personal profile.
MatthewDriscoll
Did you ever find the equivalent of the normal.mxt for Pro?
CharlesBailey3
No, we just have a doc that tells the user where to find the task and dock
it in a panel. We actually thought about setting it up manually on each
user's machine, which would be much easier than the custom configuration
and we would still have to make the shortcut for them. Let me know if you
find a better way. Thanks, cob
MatthewDriscoll
Just found this on a reddit post.  I have not tested it yet.  We have one very picky user and want to have this information ready if needed.
C:\Users\USERNAME\AppData\Local\ESRI\ArcGIS.Desktop.Config.daml
https://www.reddit.com/r/gis/comments/9gl9vr/does_arcgis_pro_have_a_way_to_save_customization/
CharlesBailey3
Yeah I remember the daml from going through the custom config tutorial. I
don't see that file on my test machine, and I think it would only be there
if someone had previously created a custom configuration. Furthermore I
don't think you could just copy this file to the folder on the target
machine ala ArcMap, because you have to set up the shortcut with the path
to the pro exe as well as the daml location. And the user.config file seems
to only contain elements pertaining to tool environment settings and such,
not the UI. However, I did find an xml file in there which seems to
reference (since I'm not an xml expert) panel docking settings kinda like
you would see on a web page so I am going to copy this file to the same
folder on another machine and see what happens - no great expectations but
will let you know. Thanks, cob
