Yeah I remember the daml from going through the custom config tutorial. I
don't see that file on my test machine, and I think it would only be there
if someone had previously created a custom configuration. Furthermore I
don't think you could just copy this file to the folder on the target
machine ala ArcMap, because you have to set up the shortcut with the path
to the pro exe as well as the daml location. And the user.config file seems
to only contain elements pertaining to tool environment settings and such,
not the UI. However, I did find an xml file in there which seems to
reference (since I'm not an xml expert) panel docking settings kinda like
you would see on a web page so I am going to copy this file to the same
folder on another machine and see what happens - no great expectations but
will let you know. Thanks, cob
