Loading shapefile directly into ArcGISPRO_3.2
251
04-17-2024 08:41 AM
MarijnKriegsman
Hello, my supervisor sent me shapefiles instead of excel sheets to use for a map. I can't seem to add them into the map when I use the add data button. When I try to add the shapefile, It just tells me "Failed to add data". Am i doing something wrong? Or is not possible to add shapefiles directly into ArcGIS?
I use ArcGISPro_3.2. I really appreciate any help:)
George_Thompson
Esri Frequent Contributor
In the location with the shapefile, can you send a screenshot of all the shapefiles w/extensions?
The shapefile needs 3 different files to make it work correctly.
Here is an example of an exported shape file: Notice there are multiple parts to the file.
  • .shp—The main file that stores the feature geometry; required.
  • .shx—The index file that stores the index of the feature geometry; required.
  • .dbf—The dBASE table that stores the attribute information of features; required
p/latest/manage-data/shapefiles/shapefile-file-extensions.htm
How was the file sent to you, zipped up or individual files?
--- George T.
George_Thompson
--- George T.
MarijnKriegsman
Thank you, this helped! I originally only received the .shp files. They just forgot to send me the other required files!
George_Thompson
Great to hear! This happens from time to time.
--- George T.
