Map Series not working with Query layer Pro 3.2
304
01-23-2024 10:13 AM
PamelaLocke1
I had a map series working in Pro 2.9 using a query layer as the layer driving the map series.  I just upgraded pro to 3.2 and this map series no longer works.
I've tested it with a regular feature class and it works.
I've removed and re-added the query layer, redone the database connection and it still doesn't work.
I'm combining the feature class mentioned above with a table in our SQL database to create the query.
The query layer and map series windows are not giving me any errors.  There are just no pages showing up in the map series contents.
Any thoughts?
PamelaLocke1
I spoke with esri, apparently, this is a known bug. BUG-000151298: Query layers made in ArcGIS Pro 3.0 cannot create map series pages.
Esri's workarounds are:
  • Export the query layer to a feature class.
  • Revert to earlier versions of ArcGIS Pro before 3.0 (Example: 2.9.x; 2.8.x).
PamelaLocke1
is there any work to resolve this issue for subsequent releases of pro?
