Once a Database View is created in ArcGIS Pro, how can I go back in and see the SQL that was used?
2150
5
04-22-2020 03:01 AM
TobiSellekaerts
I've successfully created a database view using ArcGIS Pro, using arcpy.CreateDatabaseView_management().  Now, I would like to see the SQL that was used in the creation of that view.  I could do this in ArcCatalog by right clicking on the view, Properties, Definition tab.  Is there a way to do this in ArcGIS Pro?  I tried both right click, properties and arcpy.Describe().  Since I still have ArcCatalog I've resorted to using that to view the SQL used to create the view, but am hoping I've just missed something in ArcGIS Pro.
Using:
ArcGIS Pro 2.4
ArcCatalog 10.7.1
JakeSkinner
Esri Esteemed Contributor
Hi Tobi,
Add the view to a map > right-click on the view > Properties > Source tab > click the pencil next to Query:
You should then see the SQL:
TobiSellekaerts
Fantastic - worked like a charm - many thanks!
Upon deeper inspection, this actually isn't returning the correct information.
In ArcCatalog, I see something like this:
CREATE VIEW ViewName AS SELECT OBJECTID, ATT2 AS NewAtt2, ATT3 AS NewAtt3, LEFT(SOMELONGATTRIBUTE, 40) AS NewShortAtt FROM Database.User.OriginalTable
which is what I'm looking for - the SQL which created the original view.
In ArcGIS Pro, I see something like this:
SELECT OBJECTID, NEWATT2, NEWATT3, NEWSHORTATT from Database.User.ViewName
which isn't what I'm looking for.
Apologies for not examining more closely before marking your reply as correct.
BruceHarold
Jake that's a query layer, output from Create Database View isn't showing the query for me.
TobiSellekaerts
Thanks Bruce and Jake for your responses.  I've opened a case with Esri Support and heard back that "there does not appear to be a way to do this in ArcGIS Pro currently like there is in ArcMap."  Support is lodging an enhancement request and at their request I've submitted a new idea to GeoNet:
ArcGIS Pro should allow you to see the SQL used to create a database view
I'm going to mark this question as answered, even though the answer is "You can't get there from here", and keep my fingers crossed for support in a future release.
BruceHarold
Great, I believe this has caught the attention of the right people in development so thanks for bringing this up.
