I'm trying to automate testing of a series of tools in my ArcGIS Pro Add In. Several of them rely on an active MapView and it doesn't seem to initialize properly in the context of a unit test. For example, I'd like to confirm the MapView coordinates change when a combobox item is changed, zooming to a different map tile in a dataset. Following the regression example in the community samples, my test currently looks like this:
public async Task ZoomToMapTile_ChangesMapViewLocation()
await _map.OpenViewAsync();
MapView mapView = MapView.Active;
double originXCoordinate = MapView.Active.Extent.Center.X;
Mapping.ZoomToMapTile("004");
double destinationXCoordinate = MapView.Active.Extent.Center.X;
Assert.AreNotEqual(originXCoordinate, destinationXCoordinate);
Running with breakpoints, I see the MapView populates the correct map properly, but many of the properties are null, and the IsReady property is false. Should I avoid this pattern for unit testing user controls? Is there any other way for me to automate testing?
Any suggestions or guidance is greatly appreciated.
