ArcGIS QuickCapture Blog
102
293.1K
54
POST | Hi. I would like to write Arcade code that integrates two different layers. Data Collection (DC) Layer will be where ... by MM598 New Contributor III 0 3 | 0 | 3 | 134 | |
POST | We appear to have found an issue with dynamic choice lists that use data coming from ArcGIS Enterprise. When opening ... by Amanda__Huber MVP Regular Contributor 1 2 | 1 | 2 | 112 | |
POST | I have created a quick capture project and field map project using the same hosted feature layer. Within this layer, ... by ScumBagSurfer New Contributor II 0 4 | 0 | 4 | 245 | |
POST | I'm trying to create an arcade expression based on the project user input value but I'm struggling to get it working.... by FrankHerbert New Contributor III 1 4 | 1 | 4 | 242 | |
POST | I have choice lists in a button user inputs for multiple buttons in a quick capture project. Each of the choice list... by ClintBoaz1 New Contributor III 0 1 | 0 | 1 | 138 | |
POST | Hello everyone!I'm working on QuickCapture and facing a challenge. I have a button named Button1 with user inputs, in... by WILERMJOSEPERAZAPIMENTEL New Contributor II 0 1 | 0 | 1 | 202 | |
POST | Since the enhancement of using arcade within quick capture to pull the nearest feature came out, we have used it seve... by ChrisBerryman New Contributor III 0 4 | 0 | 4 | 211 | |
POST | Testing quickcapture as possible tools that we can use to collect data on trails.I used an existing dataset hosted to... by AxelAnderson1 New Contributor 0 1 | 0 | 1 | 103 | |
POST | Is there a way to filter a choice list that has been derived from a non-hosted Portal feature layer? We are collecti... by Adam_Inglis New Contributor II 0 3 | 0 | 3 | 290 | |
POST | Is there anyway for the mobile user to view points already collected in the app? I have a feature layer with some poi... by MatthewBromley2 New Contributor 0 1 | 0 | 1 | 211 | |
POST | I have been hearing from the users , They unable to see the projects with Wi-Fi and some times cellular data connecti... by vijaybadugu Occasional Contributor II 0 1 | 0 | 1 | 215 | |
POST | When capturing photos is enabled, it would be useful to be able to provide a prompt or title for the photo screen.For... by JuliaMoloney1 New Contributor II 0 2 | 0 | 2 | 230 | |
POST | HiI try to understand why I have, some times, duplicate values in the database, coming from QCapture (capture one poi... by mfafard New Contributor II 0 1 | 0 | 1 | 283 | |
POST | 0 | 0 | 169 | ||
POST | I've created a Quick Capture project from the "Rapid Wildlife Reporter" template. When a user clicks on a button to r... by EricaNova Occasional Contributor 1 3 | 1 | 3 | 737 |
User | Count |
11 | |
2 | |
1 | |
1 | |
1 | |
1 | |
1 | |
1 | |
1 |
