Add (SUM) Multiple Rasters of different extents
19932
15
02-15-2011 10:31 AM
MichaelMarkieta
New Contributor III
I am having trouble adding multiple rasters to create an overal classifications raster.
Currently, I have 3 criteria variables (polygons), which have been converted from vector to raster. Each raster represents a different extent of spatial coverage on my map (eg, highways, land usage, pop density by Census Tract... I am creating a human influence index)
I will use a simplified grid example, such as those used in the ArcMap help/resources.
Below you will see the addition (summation) of 3 raster grids, with the output that I am currently experiencing. This is NOT what I would like. (grey = nodata)
Here is an example of what I would like to happen.
I've spent too much time trying to figure this out. I hope someone can steer me to the right tool or option/setting?
Note: I am using ArcMap 10
profchamberlain
Precisely! (Apologies if you do not have that version)
deleted-user-IR249IovB3CN
New Contributor III
The method of using Cell Statistics with a raster of values = 0 covering the entire analysis extent worked, as described above. I had issues initially with an inaccurate extent so I set some environmental parameters of the tool. They were: Set output coordinate system, set the processing extent "union of Inputs", set the 0 raster as my snap raster, and in Raster Analysis settings I set the cell size and mask to the 0 raster. After doing this the tool worked. ESRI, if your listening, a blog post would be useful to share this process/fix with the greater community.
Thank you for your help.
AndrewKamerosky
Ok, I am having no luck in following what y'all have done.  I have the same task, multiple (100+) rasters of different extents and most not overlapping (But in the same area) that I am simply trying to sum the values (0,1).  The map is going to show how many times a given cell was "treated". All the rasters have had the noData changed to 0 (Using the reclassify tool, a lot easier than raster math).
So I tried to do the cell statistics.  The first attempt started with the creation of a basemap of pixel values of 0, which covers all the other cell locations.  I then entered a subset of maps (for the one year) that included the basemap. I set it to run "sum". I then set the environment settings as mattlove described (set spatial, snap raster, raster analysis settings to the basemap and chose untion of inputs).  But I still get "Invalid Output Extent".  When I set the Processing Extent to the basemap, it runs but the output is blank/corrupted/I have no idea why there's no data.
What've done, just so I can get this rolling while someone else can help me figure out whats going wrong, is mosaic the pieces to the basemap (Using Mosaic to Net Raster).  Then I can use the Cell Statistics tool to sum all the maps now that they are all the same size.  This process is not time efficent at all, I've tried building a model to run this but that hasn't worked out yet.
Please tell me ESRI has created a tool that does this or help me figure out what I'm doing wrong with Cell Statistics that it won't cooperate.
New Contributor III
Stumbled across this issue again. Solution: Create a continuous raster with value = 0. Run Cell statistics with all desired rasters, including the continuous raster. The Overlay Statistic = "Sum". Be sure to set "processing extent" in environment settings to "Union of Inputs".
MaryCoburn1
In the environment settings (at the bottom of raster calculator) set the processing extent to Union of Inputs.
PhillipBurrows
Easy fix: use Cell Statistics tool. Select SUM as your 'Overlay Statistic' and check the Ignore NoData in calculations box
