Messages
Executing: RasterCalculator Con((Float("spainndvi" < 0.13)) & (Float("spainndvi" > 0.9)), 0, Con((Float("spainndvi" >= 0.13)) & (Float("spainndvi" <= 0.32)), (Float("spainndvi" - 0.13)) / (0.32 - 0.13)), Con((Float("spainndvi" >= 0.6)) & (Float("spainndvi" <= 0.9)), (Float(0.9 - "spainndvi")) / (0.9 - 0.6), 1)) "E:\Users\GTAV\My Documents\ArcGIS\Default.gdb\rastercalc"
Start Time: Tue Jul 04 17:25:11 2017
Con((Float(Raster(r"spainndvi") < 0.13)) & (Float(Raster(r"spainndvi") > 0.9)), 0, Con((Float(Raster(r"spainndvi") >= 0.13)) & (Float(Raster(r"spainndvi") <= 0.32)), (Float(Raster(r"spainndvi") - 0.13)) / (0.32 - 0.13)), Con((Float(Raster(r"spainndvi") >= 0.6)) & (Float(Raster(r"spainndvi") <= 0.9)), (Float(0.9 - Raster(r"spainndvi"))) / (0.9 - 0.6), 1))
ERROR 000539: Error running expression: rcexec()
File "<expression>", line 1, in <module>
File "<string>", line 5, in rcexec
File "e:\program files (x86)\arcgis\desktop10.5\arcpy\arcpy\sa\Functions.py", line 263, in Con
where_clause)
File "e:\program files (x86)\arcgis\desktop10.5\arcpy\arcpy\sa\Utils.py", line 53, in swapper
result = wrapper(*args, **kwargs)
File "e:\program files (x86)\arcgis\desktop10.5\arcpy\arcpy\sa\Functions.py", line 257, in Wrapper
where_clause)
File "e:\program files (x86)\arcgis\desktop10.5\arcpy\arcpy\geoprocessing\_base.py", line 510, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
ExecuteError: ERROR 999999: Error executing function.
An invalid SQL statement was used.
An invalid SQL statement was used. [VAT_boole_ras]
An invalid SQL statement was used. [SELECT * FROM VAT_boole_ras WHERE E:\Users\GTAV\My Documents\ArcGIS\Default.gdb\ifthe_ras1]
Failed to execute (Con).
The table was not found. [VAT_ifthe_ras1]
Failed to execute (RasterCalculator).
Failed at Tue Jul 04 17:25:24 2017 (Elapsed Time: 12.36 seconds)
