Extract Values to Points (without Spatial Analyst)
1939
10-17-2013 02:51 AM
LutzVogel1
New Contributor II
Hello, is there a way to extract values (elevation) from a grid-file by using a point-shape. I have no Spatial Analyst and also the workaround by converting the raster in to a vector format is also no solution, because the raster is pretty big (1m raster, 5x6km).
Any suggestions?
GeospatialTechnology
Have a look at the suites of tools from http://www.spatialecology.com/
Depending on what version of ArcGIS you're running you'll either want Hawths Tools or the Geospatial Modelling Environment.
Both have an 'Intersect Point Tool' that will do what you require.
LutzVogel1
New Contributor II
Thanks for reply. I´m gonna check it out.
