Hi, I did update the instance name and it looks like this now. I removed the city, state, zip field to save length. I checked each of the fields in the instance name.
Review_Approval - field type string, Length 500 No bind type ECI_ResubmissionReview - field type string, Length is blank (I will update to 255) No bind type Case_Number - field type string, Length 500 bind type is string This field has a calculation: once(concat(${Lead_ECI_EID}, format-date(${Operation_Date}, '%Y%m%d%H%M))) Lead_ECI_Name field type is null Length 500 No bind type (I used calc statement pulldata('@property', 'username') Incident ST Address - field type string, Length 500 No Bind type Operation Date - field type Date No length Bind Type dateTime
I am new at writing this statements and I am trying to get better at it. Thank you for looking at my problem.
concat(${Review_Approval}, ' || ', ${ECI_ResubmissionReview}, ' || ' , ${Case_Number}, ' || ' , ${Lead_ECI_Name}, ' || ', ${Incident_ST_Address}, ' || ', 'OpsDate: ', format-date(${Operation_Date}, '%m-%d-%Y')) |
