Using Survey 123 Connect to ask survey takers to delineate areas of interest using a geoshape. When the map loads in the Survey, the survey taker will first need to search for their aoi typically using a lot of panning and zooming over a large initial extent.
It is non-intuitive that, in order to Pan using cntrl-left click , the survey taker must first "turn off" the geoshape drawing tool.
Is there an option / method / parameter to have the geoshape icon be "off" when the map loads so the survey taker can immediately use cntrl-left click to pan?
Thank you!
