problem decode barcode
193
03-29-2024 03:19 AM
HanggarPrasetio1
New Contributor II
I am having problems decoding the barcode in Arcgis Survey123 Connect, is there a solution to my problem, how do I decode the encoded barcode? or should I use a script?
ZacharySutherby
Hello @HanggarPrasetio1
Survey123 will only return the value from the barcode and won't do any decoding itself. You can use a custom JavaScript function to decode the barcode value and parse it as you need.
Thank you,
Zach
