Hi All,
I've got a S123 Survey that is set up to pull existing data that has Attribute Rules associated with it in the SDE. I've already set up the Pro Project and the Web App for editing in that format. However, the client prefers to have a form to fill in without using a map (it's the way it's been done since the client has been here). So, my AR has calculations that are WAY too complex for the S123 form, and the result has to be set to non-editable as the calcs are set by council and the state.
Using Connect 3.17 and have the form pulling the data as it should. Tried to publish and it gives an error about custom feature service submission url is not compatible and that a field is not editable. I' attempting to publish to our Enterprise Portal at 10.9.1.
If it has an issue with one field not being editable then it seems to me that it would also have an issue with the fields for editor tracking - which will be turned on - that are non-editable as well.
Anyone have any suggestions? And not make the field editable, can't do that.
Lorinda
