I have a water utility network, and i wanted to run the isolation trace, is one subnetwork with one subnetwork controller enough? or do they have to have pressure zones in order to run the isolation trace so that it picks up the isolation valves perfectly.
Solved! Go to Solution.
Can i get an example regarding this so i would understand much better?
I would set your filter barriers to be like this:
and here are the results:
