iPhone and Flex Viewer
830
03-21-2012 10:45 AM
DavidAlford1
Can you access a flex viewer map on an iPhone?? It will open on my Droid Razr.
I know flash does not work on iPhone...Is there a workaround???
JonFisher
You can use an app like Skyfire, which renders the content on a server and streams the result to your phone.
JanieGoddard
We went on arcgis.com and built a Web Map using our ArcGIS Server custom web services layers on our forward facing server. Then we could use the web map on arcgis.com on the iphone after we shared it with our group of users. It does have popups available on the web map.
Hope this helps! Janie
RobertMyers
Here is an APP created with Flash(Flex) Builder 4.5  It's designed for the iPad but will install on iPhone. You can add your own web service to try it out.
http://itunes.apple.com/us/app/geomobile-for-arcgis/id459112762?mt=8
Interesting Article: Developing a Custom ArcGIS Application for the iPad 2 http://www.esri.com/news/arcuser/0112/developing-a-custom-arcgis-application-for-the-ipad2.html
Check out http://devgirl.org/2011/06/20/flexair-for-ios-development-process-explained/ for Flex/AIR for iOS Development Process Explained.
