Workflow Manager run custom ArcGIS Pro command does not work
577
10
02-06-2024 05:06 PM
StefanDieters1
New Contributor III
Using Workflow Manager on ArcGIS Pro 3.2 Enterprise 11.2
I have created a very simple workflow with following steps : Start, Open Pro Project Items, Stop
Within the Open Pro Project items I open a map then close it on finish. In the advanced section enable Run ArcGIS Pro command with the ID of a button command from a custom add-in.
The ribbon has the custom add-in and the command works from there.
When I run the Job in ArcGIS Pro it works fine opening and then closing the map.
However the command is not run. Just nothing happens.
In the ArcGIUS Server Manager logs I get messages about "received unexpected message() " with source being Workflow manager.
I have tested this only with button commands with an On Click trigger
The add-in was built with Pro 3.2, also tested with add-in built with Pro 3.0
Are there limits on the type of custom commands that can be run?
Any other ideas?
