Hello all,
I need to collect barcode data while completing a field survey with a Trimble GeoXH. What are the steps to get the data from the barcode scanner and into a text attribute? I have seen some posts that say it takes some customization, but no specifics.
My ideal setup would be to have a bluetooth connection to a barcode scanner. Then, when you perform a scan it populates text where the cursor is currently positioned in ArcPad. The entire contents of the barcode can be put in one field, I just want to capture it.
Any help is greatly appreciated!
Thanks for the help,
Brad
