Saving edits of point layer in the ArcPad,
3344
11-25-2013 07:57 AM
JamalNUMAN
Legendary Contributor
I couldn???t figure out how the edits of point layer are saved in the ArcPad.
Are they saved automatically?
[ATTACH=CONFIG]29323[/ATTACH], [ATTACH=CONFIG]29324[/ATTACH], [ATTACH=CONFIG]29325[/ATTACH]
I case of polyline and polygon, one needs to press ???save geometry changes??? to save the edits.
[ATTACH=CONFIG]29326[/ATTACH], [ATTACH=CONFIG]29327[/ATTACH]
Thank you
Best
Jamal
Jamal Numan
Tags (4)
HannahFerrier
Occasional Contributor III
Hi Jamal,
You are correct - ArcPad will save your Point Feature as soon as you select 'OK' and the Edit Form closes.
For Polyline and Polygon Features - you launch the Edit Form by selecting 'Proceed to Attribute Capture' - the ArcPad will save your Polyline/Polygon Feature as soon as you select 'OK' and the Edit Form closes.
This is different from ArcMap where all edits in an edit session must be saved - ArcPad will commit each feature as soon as both the geometry and attributes have been captured 🙂
- Hannah
HannahFerrier
Hi Jamal,
- Hannah
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
Hi Jamal,
- Hannah
Thanks Hannah. Good to confirm these facts regarding the difference between ArcMap and ArcPad.
Best
Jamal
