Thank you for this response it was very helpful in trying to understand what is going on.
I found the place in the synch.js code where the timezone offset is subtracted from the date during the download process. I removed the subtraction of the timezone from the line below and the dates seem to be kept in synch.
// Convert from milliseconds (epoch 01-Jan-1970 UTC) to days (epoch 30-Dec-1899 Localtime).
fieldValue = 25569.0 + (fieldValue / 1000.0 / 60.0 - (new Date()).getTimezoneOffset()) / 24.0 / 60.0;
The timezone offset is also subtracted during the upload process, but it does not effect synchronization of the dates.
// Convert from VARIANT time to UNIX time.
fieldValue = fieldValue - (new Date().getTimezoneOffset()) * 60.0 * 1000.0;
It appears to me that the ArcPad date and time is stored as local database time (days (epoch 30-Dec-1899 Localtime) and the ArcGIS server date and time are stored as UTC date and time (milliseconds (epoch 01-Jan-1970 UTC)). During the upload portion of the synch process the ArcPad date and time is converted to the ArcGIS Server format by subtracting the timezone offset. So if I have a time of 15:00 in ArcPad it still appears as 15:00 when uploaded to ArcGIS server.
If I try to synch again, the timezone is subtracted from the ArcGIS Server time during the download process. On the west coast this results in 7 hours being added to the time making the time now 22:00.
On ArcGIS Server the EditDate is in UTC Time, so there is no need to subtract the time zone offset when downloading to ArcPad. With the original code, 7 hours were subtracted from the EditDate, so that a feature edited at 22:00 on ArcGIS Server gets downloaded with an EditDate time of 15:00. So when the synch process is tried again, the EditDate on ArcPad is always 7 hours earlier than the EditDate on ArcGIS server so the feature always appears out of synch.
I am still not sure if I have this all right. I have not had a chance to double-check all the calculations but I think they are right. Basically, if a date and time are recorded as local time on ArcPad I would like the same value for date and time to appear in ArcGIS Server, 15:00 on ArcPad = 15:00 on ArcGIS Server. If ArcGIS server records a date as UTC, it should still have the same value when downloaded to ArcPad otherwise there is no way to tell which features need to be synchronized.
The solution for me seems to be to remove the subtraction of the Timezone offset on the Download.
