Update X,Y coordinates in a shapefile
1267
12-24-2012 06:41 AM
MikeRadko
I'm searching for a solution to update my x,y coordinates written to my shapefile when a feature is moved.
I am able to use the GPS to autopopulate the x,y fields in my shapefile when a point is initially collected, but there are some instances where we can't physically get close enough to a feature so we adjust (move) the feature on-screen in arcpad to better represent its true location.  However, the x,y coordinates that are stored in the shapefile .dbf are from the original gps location and I need to update those values to the new position.
One thought is to fire off a re-calculation of the x,y attribute fields when a feature is moved.  Or to calculate all x,y point features when arcpad closes.
Anyone out there who may have done this before?
Mike
Tags (3)
MikeRadko
Here's what I did to update x,y in my shapefile.  I used the onfeaturegeometrychanged event to make a call to my VBScript, which would take my selected position that was moved and re-calc the x,y position.
This is the script:
Option Explicit
Sub CalcXY
Dim objRS, f, numRecs
Set objRS = Map.Selectionlayer.Records
objRS.Bookmark = ThisEvent.Bookmark
For Each f in objRS.Fields
Select Case Ucase(f.name)
  Case "UTM_X"
   f.Value = objRS.Fields.Shape.X
  Case "UTM_Y"
   f.Value = objRS.Fields.Shape.Y
End Select
objRS.Update
End Sub
Mike
MikeRadko
This is the script:
Option Explicit
Sub CalcXY
  Case "UTM_X"
  Case "UTM_Y"
End Select
objRS.Update
End Sub
Mike
