Here's what I did to update x,y in my shapefile. I used the onfeaturegeometrychanged event to make a call to my VBScript, which would take my selected position that was moved and re-calc the x,y position.This is the script:Option Explicit
Sub CalcXY
Dim objRS, f, numRecs
Set objRS = Map.Selectionlayer.Records
objRS.Bookmark = ThisEvent.Bookmark
For Each f in objRS.Fields
Select Case Ucase(f.name)
Case "UTM_X"
f.Value = objRS.Fields.Shape.X
Case "UTM_Y"
f.Value = objRS.Fields.Shape.Y
End Select
objRS.Update
End SubMike
