Microsoft Surface
3543
02-10-2014 05:45 AM
MattZetterman
Does anybody have any experience using ArcReader (or any other ArcGIS software) on a Microsoft Surface tablet? If so which version of the tablet are you running? If not the Surface, how about another Windows 8-based tablet? Any insight would be greatly appreciated.
-Matt
RobertBorchert
Frequent Contributor III
I would strongly recommend staying away from the Surface.  It used Windows RT  and that can be problematic for ArcGIS applications.  It is also a bit underpowered.  Keep in mind most tablets are designed for reading email, browsing the internet etc..
The surface, and most tablets, are not built to be working machines.
I would recommend something more along the line of
http://www.msimobile.com/level3_productpage.aspx?cid=112&id=425
or
http://www.msimobile.com/level3_productpage.aspx?cid=112&id=440
Both very reasonably priced and have full versions of their operating systems
I tested out ArcReader on a Windows 8.1 computer with a database built using Windows XP and ArcGIS 10.2 and it worked just fine.
-Matt
