Geodatabase Questions
155
13.9M
1.9K
NOTE: Data Management ideas require a single label. See the descriptions to choose the label that best aligns with your idea submission.
Already Offered | If I understand correctly, only the latest version of the ST_GEOMETRY .dll is available in My Esri downloads.For exam... by Bud Notable Contributor 1 15 | 1 | 15 | |
Already Offered | Rework the "Batch Project" geoprocessing tool to enable the reprojection from different input reference systems, like... by ClaireCG New Contributor II 0 4 | 0 | 4 | |
Already Offered | Please certify Oracle 19.4 an up for geodatabase use with ArcGIS Desktop 10.7.1.SLES 15 support only Oracle 19.4 and ... by TomGO New Contributor II 2 11 | 2 | 11 | |
Already Offered | Currently replicas can only be synced by the user the created the replica or a portal admin. It is a common offline ... by JoeHershman MVP Regular Contributor 12 10 | 12 | 10 | |
Already Offered | In enterprise and file geodatabases, the Shape.STArea() and Shape.STLength() fields are automatically calculated afte... by MarkWarren1 New Contributor II 8 5 | 8 | 5 | |
Already Offered | It is frustrating when one wants to create symbols with the colors from polylines to polygons you have to create the ... by RobertBorchert Frequent Contributor III 3 2 | 3 | 2 | |
Already Offered | If I had numbers 1-10 in an attribute table and sorted by this field the number 10 would be placed between 1 and 2. L... by ChrisRichardson New Contributor II 11 1 | 11 | 1 | |
Already Offered | Much like the attribute table-> options-> show field aliases toggle, it would be helpful to be able to switch between... by TylerBurg New Contributor II 10 3 | 10 | 3 | |
Already Offered | You cannot remove default values from fields using a toolbox but can certainly assign them with "Assign Default to Fi... by RonnieRichards Occasional Contributor III 10 3 | 10 | 3 | |
Already Offered | We recently moved to a versioned database and enabled archiving at the same time so we can manage changes that may ne... by RobertPfingsten New Contributor II 11 2 | 11 | 2 | |
Already Offered | Currently it seems that once can use "cut & paste" to quickly move gemoetry from one shapefile / feature class to ano... by SeanGambrel Occasional Contributor II 6 6 | 6 | 6 | |
Already Offered | Change the new ArcGIS 10.1 Create Database User geoprocessing tool so that it does not grant create data privileges i... by NathanHeick2 New Contributor III 16 1 | 16 | 1 | |
Already Offered | The file geodatabase API/SDK should support any coordinate system ArcGIS itself understands and can use.After days of... by mattwilkie Occasional Contributor III 36 5 | 36 | 5 | |
Already Offered | This tool would allow you to locate the feature class/field that use a specifc domain in a workspace. by ChrisFox Esri Regular Contributor 12 3 | 12 | 3 | |
Already Offered | Pre-10 versions of Desktop allowed users to move a node along with its shared edges manually with a mouse. Similar t... by TiffanyPuett1 Occasional Contributor II 6 2 | 6 | 2 |
Idea Submission Guidelines
User | Count |
8 | |
2 | |
2 | |
1 | |
1 |
