Data Management Ideas
Other Boards in This Place
NOTE: Data Management ideas require a single label. See the descriptions to choose the label that best aligns with your idea submission.
Latest Activity (425 Idea Submissions)
Sort/Filter :
Open
Allow the Analyze Datasets tool to update all branch-versioned related system tablesOur organization manages a set of...
SeanLyons
by SeanLyons New Contributor III
in Data Management Ideas Last Updated Wednesday
2 0
Open
I am preparing branch versioned data in an enterprise geodatabase for publishing to Enterprise Portal. One of the req...
ChristalHigdon_USFS
by ChristalHigdon_USFS New Contributor III
in Data Management Ideas Last Updated 3 weeks ago
3 0
Under Consideration
In the geodatabase schema report, can a new column be added to list any additional objects (tables, feature classes) ...
JarekDomanski
by JarekDomanski New Contributor II
1 2
Open
I often need to create Table Views of linear feature class (FC) attribute tables to either create secondary geometric...
DaveMcPherson
by DaveMcPherson New Contributor III
in Data Management Ideas Last Updated 03-07-2024
2 0
Open
To date it is only possible to store geometries OGC compliant in a File Geodatabase. Accordingly ArcGIS Pro provides ...
Palladius
by Palladius New Contributor II
in Data Management Ideas Last Updated 02-29-2024
2 2
Open
When you use the Delete field tool on a featureclass in a geopackage it throws a 002557 error.My idea is simply to en...
DuncanHornby
by DuncanHornby MVP Notable Contributor MVP Notable Contributor
in Data Management Ideas Last Updated 03-04-2024
1 1
Open
One feature that we really miss is a backup function that can be triggered by the administrator at any time or on a s...
MarcoGubitzer
by MarcoGubitzer New Contributor II
in Data Management Ideas Last Updated 01-10-2024
5 1
Open
ArcPro Versioning Ribbon has a great button: Version Changes.  This provides a categorized list of edits in the given...
FredSpataro
by FredSpataro Occasional Contributor III
in Data Management Ideas Last Updated 12-11-2023
9 5
9
In Product Plan
The new Generate Schema Report tool in Pro is a great way to export the details of all objects in a geodatabase.  How...
AndrewRudin1
by AndrewRudin1 Occasional Contributor II
in Data Management Ideas Last Updated 03-21-2024
3 2
Open
Regarding the isEmpty ST_GEOMETRY SQL function: ST_IsEmpty returns 1 (Oracle and SQLite) or t (PostgreSQL) if the ST_...
Bud
by Bud Notable Contributor
in Data Management Ideas Last Updated 10-31-2023
0 0
Open
ArcGIS Pro 2.6.8, Oracle 18c 10.7.1 EGDB; SDE.ST_GeometryIf I understand correctly, a feature can either have:Null SH...
Bud
in Data Management Ideas Last Updated 11-03-2023
0 4
Open
When migrating data from a source feature class to a destination feature class (new or existing), I found an issue if...
GKing
by GKing New Contributor II
in Data Management Ideas Last Updated 08-15-2023
1 2
Open
I have been struggling with field unit conversions for many years now. The service data is NEVER in the units you des...
PDodd
by PDodd New Contributor III
in Data Management Ideas Last Updated 08-17-2023
6 1
6
Open
Current file attachment functionality is based on a 1:M relationship cardinality (a feature can have multiple attachm...
GKing
in Data Management Ideas Last Updated 06-30-2023
1 3
Closed
Allow the ability to connect to a HA database in the Add database connection box.HostName=<host1, host2>;Port=<port n...
VaibhavS
by VaibhavS New Contributor III
in Data Management Ideas Last Updated 07-21-2023
0 2
153 Subscribers
Idea Submission Guidelines
We love hearing from you about how to improve our products. To learn how to submit a valid idea, please review the Submission Guidelines
