Hi there,
The description for the Warp tool in ArcGIS 10 says "Performs a transformation on the raster based on the source and target control points using a polynomial transformation. This is similar to georeferencing using a text file." Problem is, there is nowhere for me to load the text file! I have hundreds of rasters that need to be georeferenced. How to do this as a batch process by loading a text file?
Christi
