I'm new to looking at metadata, and would like to make use of the simple 'description' metadata which ArcCatalog allows you to create at V10 for layers in SDE.
Basically I can use ArcEditor to fill out the metadata summary, credits, description, tags etc and save, but I want to access this metadata and make use of it through web applications, probably via a stored procedure that queries the relevant tables in SDE to get the metadata for a layer. I have been unable to discover where this information even gets stored in SDE (V10 on SQL Server), there is an SDE_Metadata table but this remains empty. I have found other forum posts on accessing metadata for previous versions of SDE, but not 10, and I really don�??t want to use ArcIMS �?? I've just spent the last year migrating all our apps from IMS to AGS, so installing IMS just to use a metadata service seems a backwards step.
Can anyone please explain where this simple metadata gets stored in SDE and how I can retrieve it?
Thank you,
Mark.
