Did you try searching GeoNet for an existing answer? I am quite sure this type of conditional field calculation has been covered a time or two. That said, see if the following works for you (apply to Field Y using Python parser):
!field_x! if !field_x! else !field_y!
!field_x! if !field_x! is not None else !field_y!
UPDATE:
Although my original code would have worked for most data types, it could have given incorrect answers with string fields.
Python doesn't have a data type called NULL/Null/null. The Python Built-in Types documentation states for the null object, "There is exactly one null object, named None (a built-in name)." If you are used to working with NULL in databases and SQL; be careful, None in Python doesn't behave exactly the same as NULL even though None is referred to as "the null object" in some documentation.
In Python there are several falsy values, i.e., values that are not false but evaluate to false in a Boolean context. Some common examples are None (the NoneType), "" (empty string), [] empty list, () (empty tuple), and 0 (the number zero). When using the Python parser with the Field Calculator or cursors with ArcPy, NULLs need to be converted, and Esri has chosen to convert them to None, which is understandable given the built-in data types available with Python.
The issue with my original code is that an empty string would have compared as False, the same as None, but an empty string is not NULL. Changing the code to explicitly check for None solves this issue.
