Snapping to Multiple Vertices
337
09-05-2011 01:29 AM
PaulEvans
New Contributor II
Dear all,
I would like to create a polygon of a section of this coastline using the snapping tool to snap to an existing polyline. In Mapinfo you can hold shift (while snapping is enabled) and hover over a vertice of a polygon to snap to all vertices along the line instead of having to snap to each one. Is this possible in ArcMap (I have ArcInfo)?
Kind regards,
Paul
TimothyHales
Esri Notable Contributor
I would recommend using the Trace tool.  The tool will follow along the line and snap to the vertices of the existing feature.
Creating segments by tracing
