I am trying to reproject a featureclass using the IGeometry.Project method.
When I use it to change a featureclass from Lambert to GDA94, nothing changes.
I may be making a fundamental error here as the finer points of reprojection have always exited my head after a cup of tea.
Can someone tell me what I'm doing wrong?
I am using a Windows 7 machine with ArcGIS 10.1. The application is a standalone .exe one.
My code is:
public static string reProject(string sFromWorkspace, string sFromFC, string sToProjectionFile, ref ToolStripProgressBar pProgress)
// Reproject sFromFC using the projection in file sToProjectionFile
string sError = "";
IWorkspaceFactory pFromWSFactory = null;
IWorkspace pFromWS = null;
IFeatureWorkspace pFromFWS = null;
IFeatureClass pFromFC = null;
IFeatureCursor pFromFCur = null;
IFeature pFromFeat = null;
IGeometry pGeom;
IQueryFilter pQ;
ISpatialReference pSpRef;
ISpatialReferenceFactory pSpRefFact = null;
bool bProgress = false;
int iCount;
try
if (File.Exists(sToProjectionFile) == false)
sError = "File: " + sToProjectionFile + " does not exist";
return sError;
bProgress = pProgress != null;
// From Workspace
pFromWSFactory = workspaceFactoryGet(sFromWorkspace, ref sError);
if (sError.Length > 0)
sError = "reProject\r\n" + sError;
return sError;
pFromWS = pFromWSFactory.OpenFromFile(sFromWorkspace, 0);
pFromFWS = (IFeatureWorkspace)pFromWS;
// Spatial reference
Type factoryType = Type.GetTypeFromProgID("esriGeometry.SpatialReferenceEnvironment");
System.Object obj = Activator.CreateInstance(factoryType);
pSpRefFact = obj as ISpatialReferenceFactory;
pSpRef = pSpRefFact.CreateESRISpatialReferenceFromPRJFile(sToProjectionFile);
// Open the featureclass
pFromFC = pFromFWS.OpenFeatureClass(sFromFC);
iCount = pFromFC.FeatureCount(null);
if (iCount == 0) return sError;
if (bProgress == true)
pProgress.Visible = true;
pProgress.Maximum = iCount;
iCount = 0;
pFromFCur = pFromFC.Update(null, false);
pFromFeat = pFromFCur.NextFeature();
while (pFromFeat != null)
pGeom = pFromFeat.ShapeCopy;
if (pGeom.IsEmpty == false)
pGeom.Project(pSpRef);
pFromFeat.Shape = pGeom;
pFromFeat.Store();
Marshal.ReleaseComObject(pFromFeat);
pProgress.Value = iCount;
iCount += 1;
return sError;
catch (Exception ex)
System.Diagnostics.StackTrace pStack = new System.Diagnostics.StackTrace(ex, true);
System.Diagnostics.StackFrame pFrame = pStack.GetFrame(pStack.FrameCount - 1);
int iLineNo = pFrame.GetFileLineNumber();
sError = "Error: reProject; Line: " + iLineNo + " \r\n" + ex.Message;
return sError;
finally
if (pFromFeat != null) Marshal.ReleaseComObject(pFromFeat);
if (pFromFCur != null) Marshal.ReleaseComObject(pFromFCur);
if (pFromFC != null) Marshal.ReleaseComObject(pFromFC);
if (pFromWSFactory != null) pFromWSFactory = null;
if (pFromWS != null) pFromWS = null;
if (pFromFWS != null) pFromFWS = null;
if (pSpRefFact != null) pSpRefFact = null;
if (bProgress == true) pProgress.Visible = false;
John
