POST | I'm using the DJI P4 Multispectral and trying to create process this imagery in ArcPro v2.8.3.Can I process this mult... by Sarah-CodyKnight New Contributor II 2 0 | 2 | 0 | 405 | |
POST | Hi there,Im using FMV with ArcGIS Pro 2.6.3. Got video footage from a DJI Phantom 4 using the SiteScan LE field app. ... by Xabierr New Contributor III 0 2 | 0 | 2 | 1033 | |
POST | Hi, all!I'm using ArcMap 10.7.1 and FMV 1.4.1 on Windows 10.The Multiplexer works fine for me. And the output videos ... by DanielShaffer2 New Contributor III 0 2 | 0 | 2 | 782 | |
POST | I am looking for any available best-practice data management frameworks to apply to an emerging agency drone capabili... by ElliotSimmons New Contributor 0 0 | 0 | 0 | 597 | |
POST | Hello,I used a P4 Pro V2.0 to collect some aerial images. I need more information about the drone camera to create a ... by SamuelHopstone New Contributor 0 2 | 0 | 2 | 5827 | |
POST | I am using drone2map for the first time and when identifying control for my images prior to processing I have to manu... by DavidMills1 New Contributor 0 0 | 0 | 0 | 361 | |
POST | Hi,I'm using a DJI Phantom Pro 4 to capture imagery which I then process in Drone2Map. I am trying to create an accu... by BrianBulla Occasional Contributor III 2 5 | 2 | 5 | 2242 | |
POST | Hi,I've been droning for a while now, but I'm about to do my first drone job of a gravel stockpile for a volume measu... by BrianBulla Occasional Contributor III 0 0 | 0 | 0 | 238 | |
POST | Hi folks. Im looking for assistance/advice regarding using a point cloud for a specific object detection task, ident... by MooseMartin New Contributor 0 0 | 0 | 0 | 288 | |
POST | HiHas anyone tried Ortho Maker for image server and what result did you get?See attached image for my result.Not very... by MattiasTivlin New Contributor III 0 0 | 0 | 0 | 405 | |
POST | Hi guys.Bit of a technical question here.I am experimenting with FMV on Arc and in QGIS.I used tutorial data to learn... by Pieterdu_Plooy New Contributor 0 0 | 0 | 0 | 550 | |
POST | the volume calculate in drone2map is inaccurate, what are some other work arounds that calculate volumes from drone p... by GaryWelling New Contributor II 0 0 | 0 | 0 | 221 | |
POST | Hi I tried to used drone video under full motion video extension to create map and conduct some distance measurements... by dilshandesilva New Contributor 0 3 | 0 | 3 | 943 | |
POST | I am interested in improve the capabilities of Ortho Maker. I am testing it and comparing to Ortho Mapping and I find... by AntonioSan_José_Albacete New Contributor II 0 2 | 0 | 2 | 703 | |
POST | What is your agency's Drone Use Policy?Any examples or similar detail you can share will be greatly appreciated.Shita... by BillFox MVP Frequent Contributor 0 5 | 0 | 5 | 1144 |
