Full Motion Video 1.4.1 - Multiplexer Output videos not read
829
11-03-2020 11:32 AM
DanielShaffer2
Hi, all!
I'm using ArcMap 10.7.1 and FMV 1.4.1 on Windows 10.
The Multiplexer works fine for me. And the output videos play perfectly within the FMV player. However, nothing other than the FMV player will read them.
I get prompts to download codecs that then do not work, and/or media players just crash. Typically I'm asked to download an MPEG-2 codec or encoder.
The Export Video Frames for Orthomosaic also does not recognize the output videos (I'm guessing). I get an error saying:
Value cannot be null.
Parameter name: source
Failed to execute (ExtractVideoFramesForOrthomosaic)
Is this a file type registration issue? Some other known issue?
Thanks in advance.
ScottSweet2
They apparently do not reply to posts about FMV. This was a long time ago and you never got an answer?
DanielShaffer2
Actually, I got some help directly from Tech Support and didn't think to come back here and close the thread out.
Apparently, the Codec issue is just a problem with the older version of FMV. It is supposedly resolved in current version associated with ArcGIS Pro.  But I have not tested that, as we eventually realized that the playback of georeferenced video showing the camera frame on the ground wasn't necessary for our work. So, I stopped pursuing it.
If a moderator reads this and I'm incorrect about that issue being resolved in new versions, please let the world know.
