New DB server, Oracle 19c, Failed to connect to the specified DBMS instance
1315
08-31-2023 06:56 AM
MagalyClément-Zaber
Our actual configuration is :
  • Arcgis Enterprise 10.8.1
  • Oracle 12c
We want to test the connection with a new version of Oracle : Oracle 19c.
The server is installed and connexion with "sql manager" works fine.
On my local machine, i have installed Oracle Client 19.
I want to create a geodatabase.
I modified the tsname.ora to put the new config:
SIGIMGPROD19C =
(DESCRIPTION =
(ADDRESS_LIST =
(ADDRESS = (PROTOCOL = TCP)(HOST = MYSERVER)(PORT = 1521))
(CONNECT_DATA =
(SERVICE_NAME = MYINSTANCE)
The connection test with tnsping works fine.
But when I use the tool "Create Enterprise Geodatabase", I've got an error :
Failed to connect to the specified DBMS instance (Échec d'accès au serveur DBMS)
I use a batch to execute arccatlog to use specific path :
Set PATH=C:\oracle\product\19c\cli19c32\client_1\bin;C:\Program Files (x86)\ArcGIS\Desktop10.8\bin
START ArcCatalog.exe
I there something I forgot to configure ?
Thanks for help
Tags (1)
MarceloMarques
First test the connection to the Oracle database using Oracle SQL Plus.
This will help determine if Oracle Instant Client is configured correctly.
Oracle Instant Client requires the Microsoft C++ Redistributable Library.
Look the Oracle Instant Client Installation documentation.
See my communuity.esri.com white paper.
How to Install the Oracle Database Client for ArcGIS?
I hope this helps.
| Marcelo Marques | Principal Product Engineer | Esri |
| Cloud & Database Administrator | OCP - Oracle Certified Professional |
I work with Enterprise Geodatabases since 1997.
“ I do not fear computers. I fear the lack of them." Isaac Isimov
MarceloMarques
I hope this helps.
MagalyClément-Zaber
Thanks a lot ! This helps me.
lsnrctl status  show me the error in tnsname.ora !
The service name was not complete, I have forgotten the complete DNS name.
MarceloMarques
Glad to assist.
