Convert an Orthomosaic to vector
8875
34
01-21-2016 10:33 AM
RojgarIsmael
New Contributor II
Greeting
I am Msc student in surveying engineering, I have generated an orthomosaic.tiff (its size 4.5GB) and DTM.tiff (its size 2.5GB) using Pix4D software, I need to making a vectorization to dwg or dxf in order to produce a linemap, I have tried many time to do such conversion using:
AcrToolbox->conversion tools->from raster to ployline, OR raster to polygon.
Unfortunately after a few hours of conversion nothing will display and converted file is empty.
Could you please clarify the procedure if this type of conversion is possible.
ChrisDonohue__GISP
Generally, yes, it is possible using the tools you mentioned.  But there can be issues with running out of memory.  I've never processed images as large as what you have, but have had smaller ones blow up due to memory issues.  One workaround was to split the images into several pieces, Raster to Polygon each piece separately, then rejoin the results (and then clean up the results where they joined).
Here's some folks who probably have more detailed ideas:
Dan Patterson
Darren Wiens
Chris Donohue, GISP
RojgarIsmael
New Contributor II
Dear Chris
I have separated this large size to a number of smaller tiles (200MB approx.), after separation I have tried to convert (Raster to Polygon), again the file is empty and nothing will display.
So,now what should I do?
DarrenWiens2
MVP Honored Contributor
You need to somehow generalize your imagery before you try to extract vectors from it.
Can you describe your orthomosaic? I'm picturing RGB or multispectral imagery - raster to polygon will try to draw a pixel-sized polygon around every pixel value, which is a lot of polygons. I assume you will want to first classify your raster, then clean up the classification, then export to polygons.
As for you DTM, I assume you want contour lines. You can get them using the Contour tool.
RojgarIsmael
New Contributor II
RojgarIsmael
New Contributor II
Dear Dareen
Above is orthomosaic with GSD of 2.4cm, also I have created contour line FYI.
RojgarIsmael
New Contributor II
I have classified generated DSM for DTM extraction using Pix4D software, is it possible to utilize this classification instead of reclassification by Arc Map?
DarrenWiens2
I'm not familiar with Pix4D software and don't know what the classification would be. If it's classified into the categories you're interested in having as polygons, then that would be it. What exactly do you want to export to vector? There is no function that means "export this image to vector and you (ArcGIS) need to figure what I mean by that". Do you want to extract by color (perhaps through a supervised or unsupervised classification), or maybe edges, or something else?
RojgarIsmael
New Contributor II
Darren
Okey I will reclassify using Arc Map, let me know how can I do?
What I want to export to vector is only edges/corners of  features (like playing yard, house, road, walkway, etc) as you see in the screenshot sketch.linemap shoot.jpg
RojgarIsmael
New Contributor II
Dear Dareen
Still I am waiting your recommendation about extracting ONLY edges of features.
